Cinerender - Reflections of built-in objects not displaying in render
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-12-16
12:19 AM
2023-05-11
11:34 AM
Noemi Balogh
2020-12-16
12:19 AM
Thanks in advance,
Reid
ArchiCAD 24, 25 & 26 US
WINDOWS PC, 16GB RAM, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40 GHZ, NVIDIA GEForce GTX 970, ASUS, CM6870, Rev X.0x
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-12-21 10:13 AM
2020-12-21
10:13 AM
"Limit Reflections to Floor/Sky" -- Well theres your problem. 😉
And you can try to lower the Ray Threshold if you want to tweak the result.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-12-16 11:16 AM
2020-12-16
11:16 AM
Hey Reid, did you actually pressed the render button?
The preview won't show reflections (so it can be fast).
Do you use the physical renderer or not?
Also make sure you have reflections enabled in the general CineRender options.
And you might want to up the Reflection Depth as well.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-12-20 10:26 PM
2020-12-20
10:26 PM
Hello Runxel, thanks for the reply. I checked those items and I have been rendering it instead of the preview.
I was not using the physical renderer (should I be?).
I've attached screenshots of my settings, I think the reflections are enabled and I have increased the Reflection Depth
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-12-21 10:13 AM
2020-12-21
10:13 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-12-21 10:00 PM
2020-12-21
10:00 PM
That was the issue, thanks for helping me through it!
