Visualization
Cinerender - Reflections of built-in objects not displaying in render
reidweber
Hello, Is there a global switch for reflecting objects on a cinerender surface? I'm having trouble and I've gone through both the Surface and PhotoRender settings and cannot seem to get any reflections to display from modeled items.
Thanks in advance,
Reid
ArchiCAD 24, 25 & 26 US
WINDOWS PC, 16GB RAM, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 3.40 GHZ, NVIDIA GEForce GTX 970, ASUS, CM6870, Rev X.0x
runxel
Hero
"Limit Reflections to Floor/Sky" -- Well theres your problem. šŸ˜‰
And you can try to lower the Ray Threshold if you want to tweak the result.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
4 REPLIES 4
runxel
Hero
Hey Reid, did you actually pressed the render button?
The preview won't show reflections (so it can be fast).
Do you use the physical renderer or not?
Also make sure you have reflections enabled in the general CineRender options.
And you might want to up the Reflection Depth as well.
reidweber
Hello Runxel, thanks for the reply. I checked those items and I have been rendering it instead of the preview.
I was not using the physical renderer (should I be?).
I've attached screenshots of my settings, I think the reflections are enabled and I have increased the Reflection Depth
runxel
Hero
reidweber
That was the issue, thanks for helping me through it!
