Communication ArchiCAD 14 and Artlantis 4
Hello !
I've installed ArhiCAD 14 32-bit on Windows 7 (64-bit) platform and then installed Artlantis 4 (32-bit). To select Artlantis 4 file format from the list (command Save as...) I moved the additional DLL file and APX file from converter (32-bit) into proper ArhiCAD directories, but Artlantis 4 format item was not appeared in the list.
May be I should use a 64-bit converter files ? Is result of conversion in this case will be compatible with Artlantis 4 (32-bit) or I should replace 32-bit Artlantis 4 version by 64-bit version ?
4 Replies 4
Djordje
The obvious question:
Why would you install 32bit versions when both 14 and ArtLantis 4 are 64bit?
Check the ArtLantis web site for the exporters.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
No, the ArchiCAD 14 version is 32 bit. Anyway the item with Artlantis 4 should be in the list.
But may be you tell me how user can check the type ArchiCAD version on a computer - 32 bit or 64 bit. There is no such information in dialog window "About programm"
64 bit AC is installed in folder Program Files,
32 bit AC is installed in folder Program Files (x86)!
Thank you, andro55 !
