We value your input!
Visualization
Converting 3d view to a camera
Haneef Tayob
Is there a way to save a 3d view into a camera?
I've used the orbit tool to obtain a view I'm happy with. I know how to capture the view for a placing onto a layout. Is there a way to capture the views settings and then transfer it to a camera? This would include position and heights.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
4 REPLIES 4
Hi Haneef,
In the menu "3d Navigation Extras" or something like that, you have a command called "Put a camera on the path". I guess this will do the job.
HTH.
Haneef Tayob
Dear Braza
Thanks a million - it's exactly what I was looking for
It's one of the pulldowns on the [3D Visualisation] toolbar.
regards
Haneef
Haneef Tayob
tsturm
I can a test that this technique does work. I have used this process to move saved views from Draft files to the final file.
This is the only way to move views from file to file is by copying cameras.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
You are welcome Hannef.
BTW... Thanks for the forklift object.
