Lingwisyer
Guru
Copying channel settings between materials.
Is there a way to copy the channel settings of one material onto another?
eg. I want the colour from Material A together with the bump map of Material B to make Material C
Additionally, might there be a way to insert steps into an active channel without resetting the whole channel?
eg. Shift a Noise operation into a Layer operation.
*In the 3dsMax Slate Material Editor you can link/relink each component of a texture to other textures/components. Is there an Archicad/Cinerender equivalent?
alemanda
Same questions from my side ...
I think we have to make wish for that ... especially for that
"a way to insert steps into an active channel without resetting the whole channel? eg. Shift a Noise operation into a Layer operation"
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
