This is not a Complex profile issue, but a magic wand issue.
Fills cannot handle circles and ellipses, they can only handle segments of curves. So if you are to make an elliptical shape in a complex profile, you would need to magic wand the ellipse that you drew with the arc tool, and it will break it down into smaller circular curve segments.
Now, Magic wand can't do this 1 to 1, because it needs to simplify the curves to some extent, so it has a tolerance setting for curves (Deviation from curves) in the "Design>Magic Wand Settings..." menu.
By default this is set to 40, and that basically means, it will be able to simplify ellipses smaller than 40-50 mm by a single circle.
If you go to "Design>Magic Wand Settings...", and change it to a smaller value (e.g. 1), it will be able to create smaller elliptical holes as well. Please note, that it is not recommended at all, to use curves in complex profiles, because they increase polygon counts significantly! (that is one of the reasons it is set to 40 by default).
I hope this solved your issue.
Regards,
	Daniel Alexander Kovacs
GRAPHISOFT
