2024 Technology Preview Program
Visualization
Enscape 4.0 won't open Archicad project - Mac Pro M1 Max
Johannes Oberholi
I just downloaded Enscape 4.0 as a trial version. In the 3D window of Archicad I then pressed the button “Open in Encsape” as described. Unfortunately, Encape won't open! Does anyone have the problem with derm version 4.0? I use a MacBook Pro with M1 Max chip.
Operating system used: Mac Apple Silicon Sonoma 14.4.1
14 REPLIES 14
I don´t know if to create a new user is necessary. i think i wait until the fix will be released. if you've tried Enscape's suggested solution and it works, pleas let us know.
Hi
it worked ONLY for me with a new user and no Apple user account at all. Just a blank Apple account . The problem was the Apple user account. If this can help.
now I have to switch users to use Enscape.
thanks
Paola
Ok, of course that's not an optimal solution. Does that mean if I create a new Apple user that I can then automatically use all programs? so Archicad? Or do I have to reinstall Archicad on the new user?
No you do not have to reinstall archicad as it is the same computer. Only reinstall Enscape following what they say.
no APPLE USER
best of luck !
Great, maybe i´ll try that, otherwise i will wait for the fix. All the best.
Setup info provided by author
