Exporting to Maxonform
When I select the EDIT IN MAXONFORM command form the menu in Archicad (MAC OSX), I don't seem to be able to import the object - however the Archicad environment imports fully... This mirrors a problem I had with the first install where the object would arrive in the maxonform window, but without the essential archicad environment to provide a contextual modelling base? I don't know if I should bother reinstalling again or if there is something I am doing wrong?
Ciaran
stefan
You have the full install? The ArchiCAD Add-on (APX) -- I assume you do, since the menu option is there --- the Plugin for MaxonForm (CDL).
You are calling from the 3D Window?
Nothing there? Even if you press "H" (frame scene without lights and camera)? And not in the Project Browser in MaxonForm?
Archicad-user since 1998
my Archicad Book
