2004-05-06
04:17 PM
2023-05-11
02:02 PM
Noemi Balogh
2004-05-07 09:53 AM
Nathanael wrote:It does sound like inadequate hardware; that is why you should include your hardware and OS specs, as well as ArchiCAD version in your signature. Otherwise, it is next to impossible to answer.
Nearly every time I try to save a fly-through as a quicktime movie it causes Archicad to crash. The more complex the parameters of the fly-through, the more likely it is to have a problem. I can usually save some simple fly-throughs (less than five cameras, sourced from the 3D window), but if I try to create a flythrough from the photorendering window it causes a crash every time. I'm assuming that the problem is caused by inadequate hardware but I thought there might be a way to get around this by adjusting the settings of the fly-through or of my computer. Does anyone have any ideas?
2004-05-08 12:42 AM
2004-05-08 04:16 AM
2004-05-08 08:15 PM
Nathanael wrote:
I have slightly more than 15 GBs free memory.
What's the recomended hardware setup?
2004-05-08 10:35 PM
2004-05-09 01:13 AM
