‎2006-03-28
05:37 PM
‎2023-05-11
12:33 PM
Noemi Balogh
‎2006-03-28 06:11 PM
‎2006-03-28 06:17 PM
‎2006-03-28 06:29 PM
Chadwick wrote:OK, that's just completely weird. I've never seen a frame completely fail to render.
By flicker I mean there is an entire frame with nothing rendered in it - just a the background color. Sometimes there are just bands of the rendering - by that I mean it'll render nothing until about halfway down the frame where it'll render a band of image for a little while and then proceed to go back and render nothing for the rest of the frame. The image is 900 x 500 with 150dpi. The thing is that when the banding occurs, from what I can tell, everything is rendering correctly inside of those bands. I have no idea why it would actually not render anything in some frames. Like I said, it is happening on both the dual processor computer and the single processor.
‎2006-03-28 06:33 PM
‎2006-03-28 06:50 PM
Chadwick wrote:I would not expect it to, but I could not say. I've rendered animations with trees, cars, fences, and all kinds of louvers in-frame and never run into something like this.
. Could this cause ArchiCAD to act this way on certain frames? I have no idea why that would happen on some frames and not the other though... I am rendering the same animation without the cars and people in the site to see if anything changes. I'll let you know what happens.
‎2006-04-03 04:05 PM
‎2006-04-03 06:49 PM
Chadwick wrote:It is possible that you are running out of memory; if you have a Mac user nearby, try rendering it on the Mac - addressing the memory under OSX is better. XP has 2GB limit per application.
Ok - I have had the same problem again. I try to render a 1600 frame animation of the entire building, site (mesh) and some entourage of trees, cars and people. ArchiCAD renders blank frames and the quits after about an hour. If I turn off the cars and people layer, the entire thing renders just fine. I dont know what the problem is and I've searched the forum to see if anyone else knows (which it looks like no one really does). So I guess I am more or less documenting this issue. If anyone does know what the problem might be, I would appreciate any advice.
