‎2023-06-26 05:06 PM
Hello. I have this problem: I use a special 3D grass cover, but on the visualization it looks flat and not volumetric.
How can I fix it?
‎2023-06-27 03:35 AM
Is the 'Grass' option turned on in the photorender settings?
Most of the pre-set scenes will probably have this turned off.
‎2023-06-27 03:58 AM
Do note that turning on grass will murder your render times...
‎2023-06-27 09:51 AM
You might want to only use the 3D grass up close to the camera.
Even a simple grass texture on a huge bit of terrain increases rendering times dramatically.
