ā2005-10-23
09:00 PM
ā2023-05-11
01:11 PM
Noemi Balogh
ā2005-10-24 12:51 AM
ā2005-10-24 03:11 AM
~/archiben wrote:Does anyone know if ArchiCAD ever intends on expanding this?
the max archiCAD rendering resolution is 4048x4048 pixels regardless of which rendering engine you're using.
~/archiben
ā2005-10-24 04:32 AM
grenderer wrote:i'm sure it's in their interests to provide bigger and better rendering features, but don't forget that archiCAD isn't primarily a rendering application.
ā2005-10-24 05:57 AM
ā2005-10-24 06:10 AM
Djordje wrote:
For more than the ArchiCAD max resolution, you will have to go to Artā¢Lantis ... the effect you talk about depends mostly on the texture/shader used. I rendered huge pixel counts from Artā¢Lantis, no glitch - so I would go that way if I were you.
ā2005-10-24 06:16 AM
~/archiben wrote:Yes, I do realize that ArchiCAD is an architectural drafting tool first and foremost. However as a full-time architectural renderer (27 years; last 6 on ArchiCAD) I am always looking for better and smarter rendering methods. A typical rendering size is 14 or 15" x 20" at 400 .dpi, which can then be doubled.grenderer wrote:i'm sure it's in their interests to provide bigger and better rendering features, but don't forget that archiCAD isn't primarily a rendering application.
how big exactly do you need to your images to be? maybe you could enlarge and sharpen in photoshop?
~/archiben
ā2005-10-24 07:14 AM
grenderer wrote:But, for professional quality renderings, ArchiCAD just isn't the choice anyway. The LW engine is fine for most people's needs though. A professional illustrator, however, would take the model from AC into any of a variety of specialized stand-alone rendering products.
ā2005-10-24 11:21 PM
ā2005-10-25 04:02 AM
