Ebatte
Has anyone successfully uploaded an Enscape model to web (standalone)?
I've tried for many months, using several different versions of Enscape to upload a model to the web. It always fails with an unhelpful error message "Upload failed. Try again later."
Chaos support has ghosted me and won't respond. So I'm curious if anyone has gotten this to work using MacOS.
Operating system used: Mac Apple Silicon Sonoma
Eric Batte
Principal, MG Architects
MacBook Pro M1 Max, 64GB
AC 6.5-29
3 Replies 3
pbg
I ran into this too, and after a ton of back and forth it came back to some sort internet connection hang-up... It would go thru the upload process and then pop up with that same error. My fix was unplugging my modem and resetting it. That fixed my issue. It might have to do with your firewalls/etc. I'm on a PC so not sure if any of that is helpful or not...
Good luck!
AC 26/28 USA (latest build) - Windows 11 - Intel i7 - 64 GB Ram - NVIDIA RTX A4000
Ebatte
Thanks. I've tried it from multiple locations on different networks as well. No firewall enabled, but I have yet to succeed.
Eric Batte
AC 6.5-29
You might need to ask this on an Enscape forum rather than an Archicad one.
