Learn more
lagodue
How to combine rendering techniques?
I am starting a renovation project and would like to show a presentation drawing where the existing conditions in normal, hardline, straight line mode, but use "sketch" rendering for the lines showing new work. Any thotz on how to do this?
"Bob" - Church of the Sub-Genius
Graphisoft afficionado since 1993
15 Replies 15
With manual labor (masking, erasing, painting depending on the step and application), take two renderings from ArchiCAD (one sharp, one sketch engine - same camera position) and layer the sketch on top of the sharp one in Photoshop.
Good results for this kind of thing are possible quickly by someone experienced with Piranesi, but if you do not already own it, then the cost and learning curve may be a roadblock on this project.
A plus of the Photoshop blending method - which has many variants (opaquely erase to allow color or texture from layers below to come through, for example) ... is that you can set up layer masks ONCE and then merrily revise the model, re-render, and then use the revised renders with the established layer masks to quickly incorporate revisions without having to repaint the entire collage.
(Note: only the full version of Photoshop suports layer masks. Maybe Photoshop LE 3 does, but Photoshop LE 2 does not.)
stefan
These things can also be done in compositing software such as Combustion & After Effects. And these work for animation too!
(Not cheap, so definitely not for casual use)
Archicad-user since 1998
my Archicad Book
Vitruvius
So we have Dwights book on Lightworks rendering. And arm swinging.
David Nicholson-Coles book on GDL magic.
When are we going to get Karl's book of nifty AC tricks?
There's gold in them there tips...
Cheers
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
Thanks, Cameron! As Jimmy Durante used to say, "I've got a million of 'em!"
Am thinking about shifting to writing mode later this year... stay tuned. 😉
Regards,
I made this rendering with the same method as Karl - LW and sketch rendering mixed in PS ...
Very cool.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
i really like that! very nice image.
__archiben
mate - that's great!
~/archiben
b e n _ f r o s t
Dwight
and nice massing on the design, too.
Dwight Atkinson
