Visualization
Hyperbolical surfaces
Hi, as you see I'm the new one on this forum, but I have some BIG questions First sorry about my english.
I need a help about hyperbolical surfaces.How do you model them?Do you use just archicad or some add-ones too?I really need answers because I had a lot of problems with that...
Here is a pic of that surface I'm asking for help...
5 REPLIES 5
Rafal SLEK
The easiest way is to use Mesh 3D object from Object Depository in ArchiCAD: http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/13%20Special%20Construct....
There are another solutions also - ArchiForma add-on or 3ds import to ArchiCAD.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
Thomas Holm
You've got one here:
Search for hp-flaeche.gsm on this page:
http://www.archiforum.info/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=3;t=002338#000000
Then there's one here:
http://pagesperso-orange.fr/archilib.od/
Use Tentmaker07.
Also, one here:
http://www.archibase.net/download/80.html
And if you want to use the Mesh3DV2 in the depository, check out this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=141715
Thank you fellows.But i didn't ask for gdl or built objects.I want to learn how to model them, so I will try with this mesh3D2V.Is that an add-one?I tried archiforma and everything I won except those ruled, translational and coones surfaces
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Using ArchiForma...
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
At first this tool mesh3D2V is great.Really usefull and not hard to play with it.Thank you for that. But this what Fabrizio made is excactly what I was looking for.I got archiforma just month ago, and I love it.But I said I can't made this.I read manual help several times, but when I draw those 3d polylines everything what I recieve is like a fill in 3d.
