Hyperbolical surfaces
Hi, as you see I'm the new one on this forum, but I have some BIG questions First sorry about my english.
I need a help about hyperbolical surfaces.How do you model them?Do you use just archicad or some add-ones too?I really need answers because I had a lot of problems with that...
Here is a pic of that surface I'm asking for help...
5 Replies 5
Rafal SLEK
The easiest way is to use Mesh 3D object from Object Depository in ArchiCAD: http://archicad-talk.graphisoft.com/object_depository.php?browse=Depository/13%20Special%20Construct....
There are another solutions also - ArchiForma add-on or 3ds import to ArchiCAD.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
Thomas Holm
You've got one here:
Search for hp-flaeche.gsm on this page:
http://www.archiforum.info/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=3;t=002338#000000
Then there's one here:
http://pagesperso-orange.fr/archilib.od/
Use Tentmaker07.
Also, one here:
http://www.archibase.net/download/80.html
And if you want to use the Mesh3DV2 in the depository, check out this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=141715
Thank you fellows.But i didn't ask for gdl or built objects.I want to learn how to model them, so I will try with this mesh3D2V.Is that an add-one?I tried archiforma and everything I won except those ruled, translational and coones surfaces
Fabrizio Diodati
Using ArchiForma...
Friendly
Fabrizio
Fabrizio Diodati
At first this tool mesh3D2V is great.Really usefull and not hard to play with it.Thank you for that. But this what Fabrizio made is excactly what I was looking for.I got archiforma just month ago, and I love it.But I said I can't made this.I read manual help several times, but when I draw those 3d polylines everything what I recieve is like a fill in 3d.
