2017-12-22
		10:04 AM
		2023-05-11
		11:55 AM
			Noemi Balogh
2017-12-22 11:06 AM
2017-12-23 08:05 PM
2018-01-02 10:27 AM
mikas wrote:IT almost impossible to me to render a simple scene with only 4 lights and final presets quality. I can see in your scene many lights. My question is can you use the final presets quality? I am using a Mac computer.
accidental double post, sorry..
2018-01-02 10:47 AM
Erwin wrote:Thank you Erwin
The 'final' presets are horribly taxing.
Light settings do also impact render times. It can be very tempting to turn on all the settings for visible light, smoke, beams, etc effects.
A quick way to light a scene is to use the General light, put it at infinite strenght and put it behind the camera. Think of it as one of those fancy 'umbrella' lights a photographer would bring to light out the scene.
Now chose a 'fast' render scene to begin with: Indoor Daylight Fast (Physical).
Go into detailed settings.
Turn on the lamps under Light Adjustments.
Under Global Illumination go for Preset Interior Preview.
Under Physical Renderer > Physical Camera pick F-stop, ISO and shutter speed more fitting for interior photography. Something like 5.6, 400, 1/8. But play with these settings depending on how much light you want the lens to capture.
Go in Options > General Options. Put Ray Threshold to 0 for best reflections, Ray depth and Reflection Depth up to something like 12.
This should give you some lower settings to start with. Play with the camera settings (iso etc) and turn the GI preset to Interior Final if you notice too many spots on surfaces.
2018-01-02 11:33 AM
Erwin wrote:Need help again.
2018-01-02 01:29 PM
darwinland wrote:This time I had 65 light sources total. A FullHD 1920x1080 render took several hours, depending on settings. I did adjust the settings quite a lot this time trying to find a good combination, so I can't tell exactly what those are/were. It's too tedious to write them down here, sorry. The settings were towards the upper quality of everything, though.mikas wrote:IT almost impossible to me to render a simple scene with only 4 lights and final presets quality. I can see in your scene many lights. My question is can you use the final presets quality? I am using a Mac computer.
2018-01-02 02:46 PM
mikas wrote:I appreciate the help of our colleague that make me possible to run this render with lights on. But I still have some questions.darwinland wrote:This time I had 65 light sources total. A FullHD 1920x1080 render took several hours, depending on settings. I did adjust the settings quite a lot this time trying to find a good combination, so I can't tell exactly what those are/were. It's too tedious to write them down here, sorry. The settings were towards the upper quality of everything, though.mikas wrote:IT almost impossible to me to render a simple scene with only 4 lights and final presets quality. I can see in your scene many lights. My question is can you use the final presets quality? I am using a Mac computer.
And these renders almost ate up all of my memory. I have a bunch of older Macs here, and 32GB was barely enough, 48GB was sufficient, but my poor PC (pleas see signature) did not make it with 24GB of RAM. It just quit with "not enough memory".
The picture attached probably had at least very close to one hundred light sources (done with ArchiCAD 18 couple of years ago). You can't see all lights/lamps at once, they are in the pool room back there, they might have their impact on GI and intensity of overall lighting, I don't remember exactly what settings I put in there. These and a few similar renders took something like overnight to finish at FullHD and WQHD, and at 5K it was a matter of hole day or a day and a half to finish. They used RAM a lot too, 16-32GB became very handy.
I believe that you can't have too much working RAM with higher end rendering settings.
2018-01-05 03:40 AM
2018-01-09 10:21 AM
