Visualization
Multiple Transparency, False Light
Guru
Hi all,
I appear to be getting false illumination when rendering through multiple panes of glass into a shaded space... Render settings are the default Outdoor Daylight Fast settings with the Ray Threshold increased to 10.
Ling.
5 REPLIES 5
Daniel Kovacs
I am not sure I understand what is happening in this picture exactly, but maybe what you see is just the reflection of what is behind the camera?
If you have problems with the light going through multiple panes of glass, I suggest you to read the corresponding section of this article (there is more to it than just Ray Threshold):
https://helpcenter.graphisoft.com/knowledgebase/41188/
If that doesn't help, can you send in a bigger/clearer picture, so that I can see what the problem might be exactly? (maybe compare it to what you see in OpenGL).
Thanks, Daniel
Daniel Alexander Kovacs
GRAPHISOFT
Guru
That is a door and the containing wall inside the room viewed through a balustrade and a window. On a view that looks over the balustrade, the interior is essentially black due to the lack of interior illumination.
A different location using the default "Outdoor Daylight Fast (Physyical)" settings.
Ling.
Belinda Ercan
Hi there,
Ray threshold should be decreased and Ray Depth should be increased.
This is the relevant HelpCenter article:
The relevant section is: CineRender and glass surfaces
Guru
Ray Depth is 10, enough for 3 layers of glass. Lowering the Ray Threshold does not change the result.
Ling.
Daniel Kovacs
That might not be enough. I just did a quick test here, and actually lowering ray threshold did more for me. Try setting the Ray Threshold to 1% and the Ray Depth to 30. If that doesn't solve your problem, it is possible that it's a limitation of the rendering engine, or there's something else in the way. In this case please send me the project in a Private message (in a PLA format), so that I can investigate it further!
Thanks,
GRAPHISOFT
