NEW RENDERING PROGRAM "MAXWELL RENDER"
http://www.richardrosenman.com/maxwell.htm
http://www.maxwellrender.com/indexeng.html
Check this out
CEE YE
Still at begining but it pomise !
44 Replies 44
and the same one with a little filtering
...Oreopoulos - make sure and play with the Fstop and SS and blades angle...
Also where is your sun? It is seems to me that you do not have direct sun light entering into your scene..
cy,
Andronikos
Petros Ioannou
Does anybody have any information about maxwell's material editor?
Is it true that the final stand alone version will be much faster than the beta versions?
thanks in advance
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
thanks in advance
Petros
about the mat. editor: nobody has any info.
about speed: nobody has mentioned that MXW will be a lot faster! It is not yet optimised for speed...They are working on bugs and C4d SDK and other 3dprograms. Speed will be better but nobody knows how much.. not even Oscar I guess.
Can we download a demo from somewhere?
On Maxwell's site they just offred to sell the application.
I wouldn't spend about 1000$ on someting I havent tried!
The current state of maxwell is alpha.
The price is 395$ (60% less than the price you have to pay for the final in june). No download (this is not a final product).
And one more rendering with maxwell
Petros Ioannou
Andronikos,
nice renderings!
Did you used the 3ds max plug-in? (as I can see, you are a C4D user...)
Petros
32 GB 2400 MHz DDR4
....waiting for C4D plugin - so now I am using MXW with max7 trial
stefan
That's what every beta-renderer says... There are not many finished programs that can deliver a truly fast renderer... It's all about tweaking and cutting corners if it needs to be fast.
nVidia has now the "Gelato"renderer, which is something in the range of Renderman, but meant for GPU (hardware rendering using your 3D-card). It's faster then Renderman, they claim, but not an order of magnitude faster...
Archicad-user since 1998
my Archicad Book
similar to gelato... the artvps and it is in the market 2 years now.
http://www.artvps.com/
