Network Rendering for Lightworks?
Hi there I was wondering if Lightworks engine supports network rendering.
12 Replies 12
No. The LW implementation in AC 9 will utilize up to 2 processors on the host machine only.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
fuzzytnth3
To get round this I use as many Macs I can get my hands on in the office.
Then just open "As Read Only" the file I want the renderings from assuming you have cameras and or Publisher settings set up for each location.
If you are doing a movie tell it to render a range of frame numbers and join the finshed movies together using QuickTime Pro
eg.
Frames 1 to 100 on one Mac
Frames 101 to 200 on the nerxt etc.
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
TomWaltz
That is one serious advantage of Cinema 4D over Lightworks for animation renderings: network rendering (especially when you have 50 G5 machines!!)
Tom Waltz
Which render program I could move all the materials, scenes etc from archicad 9 so that I can do a network render? Is maya good? 3d max?
Think not only about the program, think about the support - For example the render farms and their features, prices.
This farm is downright awesome,
http://www.renderking.com/
Mark
stefan
3ds max (and the cheaper VIZ) come with unlimited rendering licenses. PC-only (obviously).
I thought Lightwave allowed it too.
Cinema4D off course, but the XL has three licenses (IIRC). You can buy more in other bundles or as a seperate module.
Maybe it's time for a Dual Processor machine, with two Dual-Core AMD Opteron processors: maybe not 4x but it should be much faster.
Or investigate in an ART VPS PURE-card, for hardware-based rendering (provided you use 3ds max or Maya and utilize the Renderman-materials). --> Maybe this is not a simple solution.
Archicad-user since 1998
my Archicad Book
fuzzytnth3
While not in the same league as Maya etc Strata CX has an excellent render engine plus it does come with a separate renderer that can be installed on as many machines as you like and works on Apple Macs and PCs
Some examples here...
www.strata.com/
More info on RenderPro here...
Strata RenderPro
www.maxwellrender.com
Have a look
fuzzytnth3
Have a look
www.maxwellrender.com/
I think you mean Maxwell not Waxwell sounds like some thing you use on your car
