Visualization
PhotoRendering completely blue please help!!
Jackcowdrey
Hi all,
I am having trouble with photorendering certain views that I have set up. Recently, for reasons I do not know why particular views I have set up and rendered a thousand times now appear blue and green in the viewpoint and when I render. Some of the views I have saved do this and some do not, I have gone through the settings of the ones that do this and the ones that don't meticulously and cannot find out what is causing this.
Has anyone come across this before and able to help?
Thanks
10 REPLIES 10
Lingwisyer
Guru
If you do a render with just the ground plane, does it still render blue? If so, you could just select the ground plane, then go File => External Content => Save Selection as Module => Uncheck "Replace Selection" => File - .pln. This should create a copy of the selected elements in a new file with the same template and attributes which you would then be able to share?
