Visualization
QUICKTIME
Seiss Wagner
How do you slow the movement between cameras when making a walk-thru in ArchiCad? My walk-thru looks like I am racing the clock to get along the path, running as fast as I can if you will; when what I really want is a leisurely Sunday walk on a hot afternoon, almost as if I were in slow motion.
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
Djordje
Increase the number of the frames between the cameras.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje has the answer, but you can also stop at Cameras for a specified number of frames. The good thing is that you can set a different value for each Camera.
Djordje
Whoa ...
Doing that would be like riding a Dubai taxi: full acceleration, then hard braking, speed bump, full acceleration ... repeat loop.
So, combine both advice: larger number of the frames between the cameras AND stopping at cameras for a number of the frames. Intersperse the moving clips with still renderings of good views. Continuous movement produces the same effect as angry Dubai taxi driver (hint: remove braking from the sequence above ... and the sparks fly!)
Djordje
HP Omen
