Visualization
Render your model with built-in or 3rd-party solutions
QUICKTIME
Seiss Wagner
How do you slow the movement between cameras when making a walk-thru in ArchiCad? My walk-thru looks like I am racing the clock to get along the path, running as fast as I can if you will; when what I really want is a leisurely Sunday walk on a hot afternoon, almost as if I were in slow motion.
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
3 REPLIES 3
Djordje
Increase the number of the frames between the cameras.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje has the answer, but you can also stop at Cameras for a specified number of frames. The good thing is that you can set a different value for each Camera.
Djordje
Whoa ...
Doing that would be like riding a Dubai taxi: full acceleration, then hard braking, speed bump, full acceleration ... repeat loop.
So, combine both advice: larger number of the frames between the cameras AND stopping at cameras for a number of the frames. Intersperse the moving clips with still renderings of good views. Continuous movement produces the same effect as angry Dubai taxi driver (hint: remove braking from the sequence above ... and the sparks fly!)
Djordje
HP Omen
