Quick time movie file trouble
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-08-01
12:56 AM
2023-05-11
02:13 PM
Noemi Balogh
2007-08-01
12:56 AM
Do you know the reason?
Something to do with Quick Time?
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-08-01 02:54 AM
2007-08-01
02:54 AM
IT could be any number of reasons.
It's usually a better idea to render to a series of frames (tifs, jpgs, etc), then assemble them into a movie. If you crash, you can pick up where you left off.
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-08-01 11:46 AM
2007-08-01
11:46 AM
First to avoid crashing I have uninstalled Quic Time and reinstall from original CD from Graphisoft.
I think AC has trouble with any update version from Quick Time.
Your suggestion rendering to a series I couldnt follow.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-08-01 02:03 PM
2007-08-01
02:03 PM
When you create the Walk-Through, one of the format options is JPG (instead of MOV), That saves each frame to a JPG file in a folder you designate.
If the walk-through crashes, you still have all the frames that Archicad made before it crashed. You can also use this method to imitate a render farm by setting each one of several machines to render a range of frames in the walk-through.
Tom Waltz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-08-01 06:19 PM
2007-08-01
06:19 PM
Sorry hard to understand...
It works also for animation?
Do you mean the surface of material in OpenGL modus?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-08-01 07:29 PM
2007-08-01
07:29 PM
I also do this to make animations but with Artlantis. You will need a movie
editor program (I use Quicktime Pro) to import the images into a sequence.
I like it this way b/c I can even set my frame rate to speed or slow down the animation as a whole or just in different sections.
Hope this helps?
Hope this helps?
Robert Fuchs
Miller Bosksus Lack Architects, P.A.
2x2.26GHz Quad-Core Intel Xeon w/10 GB RAM
Mac OSX 10.6.4, AC 14 (3004 USA Full)
