keene kopper
Reflective floor needs to stop bouncing its color on other objects
I have a pretty saturated floor color for which I want to have high reflectivity, but not have it bounce its color onto other objects nearly as much, or at all. As you can see in the screenshot, the ceiling, which is supposed to be white, is receiving a ton of red from the floor, as are the walls, but thats less identifiable in the screenshot. I'm using cinerender. Any help would be hugely appreciated!
Operating system used: Mac Apple Silicon Sonoma
TV / Film Production: Sr. Set Designer
Art Directors Guild, Local 800
Archicad Latest Version
MacBook Pro (15-inch, 2018), 2.9 GHz Intel Core i9, >32 GB 2400 MHz DDR4, Radeon Pro Vega 20 4080 MB, Intel UHD Graphics 630 1536 MB
1 Solution
Eugene
I would say it's probably Attenuation and the Layer Color in the Reflectance rollout - that's where I would start at least. I have also used the ceiling as an illuminated object to bump up GI generally, this would probably also get rid of it.
Go to post
4 Replies 4
keene kopper
Eugene
keene kopper
I tried to adjust the Attenuation and Layer Color, but that didn't really do anything, at least with the non-physical render. I did at illumination to the ceiling, and that did help a lot. Thanks for that suggestion!
runxel
You could also try to set the Saturation of the Seconday rendering method to 0 (zero). I'm not sure about the material, but there must be some setting in the material too, can't recall right now.
From the Archicad Help:
