Visualization
Render 360 Panoramic Image
derekjackson
Hi, has anyone successfully managed to use CineRender's Cylindrical Lens effect to achieve a 360 panoramic image?
I'm thinking the sort of thing I could then upload to Yulio or RoundMe to achieve 'VR'...
I can't work out the settings - what on earth is the 'Vertical Size' parameter about? And how does it relate to my image size?
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
Erwin Edel
I tried it in ArchiCAD18 for a bit and gave up trying to figure it out.
Same questions as you have.
Tried some simple 4 wall model as I recall, I couldn't make much sense of it.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
derekjackson
Anyone? Surely the folks at Graphisoft who put the option in can explain a bit about what its for? The online guide doesn't give much away...
AC19 / 21 / 23 / 27
Erwin Edel
Maybe you can find some information for Cinema 4D for it, the help documentation is very bare for this option.
www.leloup.nl
