Check that you have enough RAM for rendering.
Check that the camera is not inside a wall or object or the like. If you save the camera in to a path, you can show it on floor plan. Saving camera is a good idea also to be able to reproduce the excact same render later, if you make changes to the design.
Check that light is turned on (at 100%) in the Cinerender settings.
Try some of the preset scenes. Start with the 'quick render' ones, working up to medium. Final render settings are very heavy and often not needed.
Read up on known issues here:
http://helpcenter.graphisoft.com/troubleshooting/3d-modeling/texture-overwrite-fails/
Most common setting to tweak for nice results:
http://helpcenter.graphisoft.com/troubleshooting/3d-modeling/texture-overwrite-fails/#CineRender_and...
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
