‎2006-03-21
07:56 PM
‎2023-05-11
12:33 PM
Noemi Balogh
‎2006-04-03 02:36 AM
Scott wrote:I would still use Lightworks. The time cost of one-way, non-updating file exports is pretty high... It's one of the biggest reasons I use C4D as an external renderer.
Somewhat off topic but related question; if Artlantis R or S were included with the purchase of AC (no price add), would anyone continue to use Lightworks for renderings? Any qualities with Lightworks that beat out Artlantis aside than that LW is bundled with AC?
‎2006-04-03 03:00 AM
The time cost of one-way, non-updating file exports is pretty high... It's one of the biggest reasons I use C4D as an external renderer.Thanks Tom,
‎2006-04-03 05:21 AM
TomWaltz wrote:Non updating?
‎2006-04-03 05:51 AM
Scott wrote:If C4D were free, not a chance. I'd be using C4D for everything in sight. It can do much better rendering, camera movement, and object animation. It's only the higher end animation that I use it for now.
Tom Waltz wrote:The time cost of one-way, non-updating file exports is pretty high... It's one of the biggest reasons I use C4D as an external renderer.Thanks Tom,
So if C4D were bundled with AC with no added cost, would you still use LW? Also, how's the learning curve for C4D?
‎2006-04-04 07:48 AM
TomWaltz wrote:Scott wrote:I would still use Lightworks. The time cost of one-way, non-updating file exports is pretty high... It's one of the biggest reasons I use C4D as an external renderer.
‎2006-04-04 01:16 PM
Ignacio wrote:How does it's update work now? Is it a plug-in that you save from Archicad? (like C4D's does?) Or something else? That's really great if they finally got a better export/update system.
Artlantis updates at least as seamlessly as C4D.
A C4D guy in the office drools at and envies what I can do in Artlantis R in minutes. And I drool at and envy what he can do in two or three days, using a render farm.
‎2006-04-05 05:08 AM
TomWaltz wrote:The same technique has been around since Art•Lantis 4 or so ...
‎2006-04-05 06:32 AM
TomWaltz wrote:What I meant was that, especially after you have worked on a couple of models and can open your model 'with reference' to a previous model as Djordje said (a previous model of the same project or even actually some other project, in which case you are just using it as a conversion template for materials and a storage bin for heliodon settings and light and camera settings), you can get pretty impressive results after a few minutes' setup and a 20' rendering. With a cool illlustration atmosphere, believable lighting, etc. I get the 'is that not a photograph?' all the time, from admittedly not highly visually literate observers (which happens to be what most people are). You can get a pretty impressive full presentation in a couple of hours.
Are you implying C4D renders slowly? That's definitely not been my experience.
‎2006-04-06 10:38 AM
Djordje wrote:
So it has been there all the time ...😉
‎2006-04-06 07:52 PM
In Artlantis ...you'll be eating your nails away as you stay up overnight watching the rendering progress...Agree with all that you say, but am curious if you have a quad processor Mac available and if you've measure the performance of Artlantis R on it? Artlantis R has supported dual processors for several hotfix versions, but I thought it supported arbitrary numbers ... but did not see any good numbers on the results on a quad on the Artlantis forums. (No substitute for a render farm, of course, just curious.)
