eldhead
Save as 3ds
When Im trying to save to 3ds from 3D-window, I get this error:
improper fileformat
If I dont use any textures it works fine.
Archicad 7 - 24, HP ZBook 15 Mobile Workstation, Win 10
14 Replies 14
Dwight
so bmp's still don't work. no surprise.
Dwight Atkinson
eldhead
Just found out that 3ds has a stupid limitation of 8 signs in filenames.
Djordje
You obviously never worked in 3DS 3 in DOS ... 😉
EVERYTHING was 8.3 then ... talk about cryptic file names!
Today I wanted it back ... why do AutoCAD users have to write a short story in the filename?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
stefan
The 3ds-file format is from the DOS Days. No direct solution, unless you use 8.3 texture names in the ArchiCAD model.
I never worry about filenames, but when I export a 3ds-model from ArchiCAD, the file format only has place reserved for 8.3 characters, so I can expect some manual material assignment.
I usually only keep the ArchiCAD geometry & the texture placement. Once I got it in 3ds max (or VIZ or Cinema4D) I can use the superior materials in those programs, but don't have to worry that it's not placed correct.
The 3ds-importer is a plugin (which is included in ArchiCAD 9.0, IIRC, in the goodies). The 3ds-exporter is also an ArchiCAD-plugin which is enabled by default.
The 3ds-importer for older versions of ArchiCAD was never included.
Archicad-user since 1998
my Archicad Book
Aha! So it is. Thanks, Stefan. 😉
