Visualization
Shadowclad walling
KeesW
Does anybody have a shadowclad surface, or material, that I can use on an AC19 photorealistic rendering? Shadowclad comprises 12mm thick plywood with 9mm wide x 5mm deep grooves at 150mm centres. I need to run the grooves vertically.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
Erwin Edel
It sounds like what we call 'channelsiding' here.
There are surfaces in the library for that. At least on the Dutch version.
To get the size to work, just look at how many boards the surface has (six in this case) and adjust the size. So in this case: 6 x 150 = 900 mm.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
If you make a new surface, there should be the option to make a new one from the catalog, there you should be able to find the preset.
www.leloup.nl
Windows 10 Pro
Erwin Edel
Some tutorial vids that might help:
https://www.youtube.com/watch?v=5jmfDf_HVA4
https://www.youtube.com/watch?v=Oylp-Ix5GUE
Good luck!
www.leloup.nl
Windows 10 Pro
