Visualization
Show some of your Renderings
I thought it would be a fun idea to show some renderings of homes you've designed in Archicad, kind of like a little portfolio or show and tell.
So I'll start with a few:
361 REPLIES 361
alot of time modeling. gives you more realistic results.
all of those images had hundreds of hours in them. just making the model and custom making most of the materials.
but once you start to make all of your materials yourself, you can re-use them. so it gets faster.
to do a 3D section like this i did it with the "cut 3D planes tool"
then used the light works rendering engine like any other render.
use the help menu inside ArchiCAD to find "3D Cutaway" and how to use it
GeNOS wrote:
how do you get 3d details to look that good (adon) ??
mine are just basic line work and solid colour.. i cant find any settings where i can get it to be a rendered image
You may be interested in this article if you hadn't seen it before -
http://www.aecbytes.com/tipsandtricks/2009/issue40-archicad.html
It uses the 3d document feature to produce an exploded axonometric.
Djordje
Just a note ...
From this part of the world, Flickr is blocked ... so we can't see your work ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
for those in UAE
Djordje
Not all renderings ... 😉
http://www.facebook.com/album.php?aid=2020823&id=1124127154&l=81253ff88a
Djordje
HP Omen
Erika Epstein
Djordje,
Wow! What an impressive body of work! Which software did you use besides archicad? Is the Qatar Airways lounge Doha done with Piranesi?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
Erika wrote:
Djordje,
Thanks, Erika You do collect some stuff after a couple of decades 😉
Not all my design ... Some of it is presentation work only, like the Qatar airways lounge.
Yep, Piranesi. Pre 1995 was done in 3D Studio 2 or 3, the second (sports hall, my design that maybe even got built) in AccuRender ... modeled in AutoCAD 😉 The rest, from the modernist villa onwards, is ArchiCAD, Artlantis and Piranesi.
Djordje
HP Omen
NightClub interior I recently designed.
A Theme Bar for the same client.
Yes, those a dried Puffer Fish lamps above the bar
Nice work, Ed. I take it you didn't get the puffer fish or hula-girl lamps from the Object Depository.
