2009-08-09
04:22 PM
2023-05-11
12:15 PM
Noemi Balogh
2010-02-13 07:47 PM
TMA_80 wrote:
ejrolon wrote:i don't know how eficiente it is ( and I don't think it could reach the c4d importer ) but there seem to be an equivalent for 3dmax
AFAIK there is no equivalent for 3DS+Vray
http://www.scriptspot.com/3ds-max/scripts/archicad-importer
2010-02-13 08:07 PM
TMA_80 wrote:
Hi !
In the Agsvis (who developped vray for sketchup & Rhino )website , ArchiCAD was leading the vote for the product for which we like to have a VRAY plugin integrated to...however
http://forum.asgvis.com/index.php?topic=6439.msg36263#msg36263
2010-02-13 09:54 PM
2010-02-13 10:09 PM
2010-02-14 03:23 PM
2010-02-23 07:55 AM
TMA_80 wrote:
Hi Bricklyne
Thanks for sharing your work, (and for the author of this thread) it is really intresting to see how the combo mw+archicad is doing "well". rendering with maxwell from AC is great (except rendering time.BTW as i remember from earlier posts you're using Vray too, how does it compare & how much do you use MW compared to Vray?
As for the 3ds plugin I think you're refering to this plugin from Marc Lorenz
http://plugins.angstraum.at/archicad_wiz/index.htm
the one i mentionned in the last post seems different : it was created by olivier Gras ; see his post here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=142704&highlight=3ds#142704 .
2010-02-24 03:19 PM
2010-02-24 04:45 PM
2010-02-24 05:19 PM
Cian wrote:Nice technique but I'm not clear what the story is. That is to say, why are we looking at this building from this angle at this time of day? And why the red car?
This is my latest piece.
Modeled in AC & Cinema. Rendered in Vray and post in Photoshop.
Hope you like.
Cian.
2010-02-25 05:45 AM
SiRowe wrote:
Bricklyne,
Can I ask where you got your furnishing and fitting objects? They may not be as high-poly as 3Ds max etc would allow but they seem to render out quite well? I just often struggle to find suitable objects.
I've always found that high-poly models which are suitable for renders seem to massively slow ArchiCADs performance. Yet the AC library objects are often too low-poly for convincing internal renders...
I guess the ideal would be objects with adjustable poly counts, allowing for quick performance in a working model and still creating interior renders without the need to replace entire objects.
Thanks
