Sketch rendering
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-07-08
01:52 PM
‎2023-05-11
12:03 PM
Noemi Balogh
Another thing is that I would like to render the windows in a grey color instead of white. is this possible or do i have to run i through photoshop?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-07-08 06:35 PM
kevinerhard wrote:As far as the corner is concerned (assuming you're talking about the corner line), I don't see why it wouldn't be there..
Hello I'm having a problem in sketch rendering The corner (marked by the red box) is the same as the other picture showing that they are correctly joined. but as you can se e i'm getting a line in the facade that shouldn't be there and i don't know how to remove it?
Re: Windows - unfortunately, it can't render any of the percentage fills from what I can tell. You could use a hatch pattern like a 1" grid (this may or may not meet your criteria). Or as you mentioned earlier you could use Photoshop.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-07-09 01:24 PM
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-07-09 10:58 PM
You might want to try shifting the origin of the hatching on that wall a little to the right (your right) through the Align texture command, in the 3D window.
The vectorial hatching is tied to the texture map, so, as you adjust the origin of that, the hatch should adjust as well.
It may just be that the brick hatch is not cleaning up as well in tiling, as the image map would in full texture mode.
As for your second question, what you probably might want to do is apply a vector hatch to your glass setting to something like 10%, 25% 50% or so, depending on how dark you want it to appear.
Remember that the Sketch render is vector-based, so it doesn't do actual greys. Just strictly black and white lines and dots.
But you can simulate greys and transparency of greys through the % hatches (which are basically just black dots against a white background dispersed according to whatever concentration the percentage dictates.)
Hope this helps....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-07-10 05:45 PM
Bricklyne wrote:I mentioned earlier that:
junior wrote:...But I could be wrong (and I currently only have access to AC11)... Can you verify that the Sketch Renderer in your AC version will in fact render those percentage fills/hatches?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-07-10 06:23 PM
junior wrote:You were right.Bricklyne wrote:I mentioned earlier that:
Thanks
It only renders vectorial fills in ArchiCAD 17 as well, and unfortunately there's no way to simulate the grey with what they have available unlike with the solid fills.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-07-25 08:44 AM
kevinerhard wrote:Hi Kevin,
Starting from ArchiCAD 18 you have better control on similar situations. See the following screenshot for the new checkbox in wall settings, that can help to remove the unnecessary line from the facade.
I hope this helps,
Marton
Chief Product Officer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-30 09:51 AM
We have added a wish about this desired feature in our database!! Thanks,
Implementation Specialist
GRAPHISOFT
