2014-07-08
01:52 PM
- last edited on
2023-05-11
12:03 PM
by
Noemi Balogh
2014-07-08 06:35 PM
kevinerhard wrote:As far as the corner is concerned (assuming you're talking about the corner line), I don't see why it wouldn't be there..
Hello I'm having a problem in sketch rendering The corner (marked by the red box) is the same as the other picture showing that they are correctly joined. but as you can se e i'm getting a line in the facade that shouldn't be there and i don't know how to remove it?
Another thing is that I would like to render the windows in a grey color instead of white. is this possible or do i have to run i through photoshop?
2014-07-09 01:24 PM
2014-07-09 10:58 PM
2014-07-10 05:45 PM
Bricklyne wrote:I mentioned earlier that:
As for your second question, what you probably might want to do is apply a vector hatch to your glass setting to something like 10%, 25% 50% or so, depending on how dark you want it to appear.
junior wrote:...But I could be wrong (and I currently only have access to AC11)... Can you verify that the Sketch Renderer in your AC version will in fact render those percentage fills/hatches?
unfortunately, it can't render any of the percentage fills from what I can tell.
2014-07-10 06:23 PM
junior wrote:You were right.Bricklyne wrote:I mentioned earlier that:
Thanks
2014-07-25 08:44 AM
kevinerhard wrote:Hi Kevin,
2015-03-30 09:51 AM
