2024 Technology Preview Program
Visualization
Sliding window opening arrows disappear in elevation when changing glass material
Salto16
When I change my glass material transparency to 49% because I don't want to see through my windows in elevation my sliding window arrows disappear. (See image below.)
Transparency is "on" in my elevation settings, because I want to see through my railings.
When transparency is "off" there are no arrows at all despite what glass material I use.
(AC26)
OK, how thick is your glass?
I just looked at the sliding window in 25 AUS library, and there is an opening line on each side.
They match the thickness of the window sash.
But if the glass was too thick, it would cover them.
4 REPLIES 4
The indicators may only be scripted to show on one side of the glass.
Have a look on the other side.
If that is the case, there is probably not much you can do about it (unless there is an option to show indicators on both sides).
If it is only on one side, make sure you are placing the door with the reveal on the outside of the wall.
Salto16
If I make an elevation from the other side, the situation is the same (see image). Only windows which material transparency is 51% and up shows arrows.
In the window settings preview image shows arrows only if the material is 51%.
And I don't want to see through my sliding windows, that's why the material has to be 49%.
Sad thing is that there are no arrows in elevations and in the schedule too.
Salto16
Yes, you are right! My glass was too thick. I made it thinner and the arrows appeared.
Thank you!!
