Hi James,
Thanks for offering some help!
I did get the noise effect to work (maybe I didn't phrase that clearly, sorry!)
I just don't understand how to end the cone-shape with a cut off disc to mock up the shape of the lamp fixture.
See below for my results.
Edit: to further explain the 'problem', I have a model for a stage-spotlight that obviously has quite a diameter disc shaped end, the general light beam thing ends in 0 diameter, so the look doesn't add up. The beam should end with a similar diameter as the end of the fixture (hope this makes sense!)
I can fake the disc with a glowing surface, perhaps, but the beam is still too narrow at the end.
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
