Surfaces with same material not always merging
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-08-06
12:07 PM
2023-05-26
02:55 PM
Rubia Torres
2019-08-06
12:07 PM
Any ideas why objects applied the same material isn't always merging?
The problem only seems to occur sometimes - see red markings in attached image
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-08-08 03:02 AM
2019-08-08
03:02 AM
Check your layer priority numbers in layer combinations. This is often a reason.
Set all layer priority number to #1. This should allow everything to clean up properly (if materials are set correctly).
ArchiCAD 10 - 25 | Windows 10
ARCHIcreate | Perth, Western Australia
archicad solutions | content creation | training | software implementation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-08-06 01:09 PM
2019-08-06
01:09 PM
I'm afraid most of the time this is due to inaccurate modelling on the user end. If you zoom in enough, you will probably find that the elements do not sit flush together but have a small offset / other 'mistake'.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-08-06 04:14 PM
2019-08-06
04:14 PM
Erwin wrote:Yes... I think you're right even I cannot seem to find the mistake.
But I'm new to Archicad and struggles a little with the snap points and references... so that's properly it
Thank you
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-08-08 03:02 AM
2019-08-08
03:02 AM
