Visualization
Tips to adjust surface orientation on Doorleaf
Thomas Nymann
Hi.
Does anyone know whether it is possible to adjust the orientation of a Door Leaf Surface, besides creating an additional surface Attribute ?
It would be much appreciated 😉
Cheers
Thomas
ASUS ROG I9 12900H 🙂 - RTX 3080ti (16GB) - 32 GB RAM - Ryzen 7 1700X 3,8GHz. - GTX 1080ti 11 GB- 16GB RAM
AC 13 +
1 REPLY 1
Erwin Edel
You would have to create a custom door leaf with proper texture allignment / orientation. Sadly you can't pass along the surface parameter to a custom panel afaik, so you would end up with having a custom panel for each surface. So having 2 surfaces is probably a lot less of a hassle.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
