2023-01-12 11:41 AM
Hi.
Does anyone know whether it is possible to adjust the orientation of a Door Leaf Surface, besides creating an additional surface Attribute ?
It would be much appreciated 😉
Cheers
Thomas
2023-01-12 12:07 PM
You would have to create a custom door leaf with proper texture allignment / orientation. Sadly you can't pass along the surface parameter to a custom panel afaik, so you would end up with having a custom panel for each surface. So having 2 surfaces is probably a lot less of a hassle.
