‎2021-03-30
03:55 PM
‎2023-05-11
01:38 PM
Noemi Balogh
‎2021-03-30 04:49 PM
‎2021-03-30 04:59 PM
Erwin wrote:Thanks! I didn't think I change the quality after I did the changes, but I'll try again just to be sure!
When you say 'medium' quality, are you referring to the preset scenes? These will reset the values you've changed.
Another option could be that you are running out of memory on the higher settings, but I'm not 100% sure about this.
Personally I've gone from a quick render preset and tweaked settings until things looked good enough. I find the medium and final presets to take a rediculous amount of time. Maybe play with global illumination quality from the quick render that works to see how that goes.
A problem I ussually have with interior renders is getting the image bright enough without artifacts. For this I find that placing a general lightsource behind the camera to illuminate everything evenly helps to keep speed and quality both good.
Ambient Occlussion is ussually what makes things take very long. For this I found a good tutorial to do these in a separate render:
I turned on automatic translated subtitles to help understand the russian and by carefully comparing between the video and my AC20 interface managed to recreate the workflow.
Last tip: consider the size of your render. I generally render 195x135 mm at 300 dpi. This is fine for viewing on HD screens, smartphones and printing at 100% scaled to A4.
‎2021-03-31 01:49 PM
