Wall texture material
Hi All,
I was wondering if anyone knows how to put two different texture material on a same wall? I a trying to create one single wall where the bottom portion has a different texture than the top part.
I.e. bottom part= stone top part= bricks.
Is it also possible to separate the texture horizontally and vertically at the same time?
Thank you for your help in advance!!
Sincerely,
DDJUSA
4 Replies 4
you could create a short wall and then create one over it
for example, you create a 1500 height wall which is 0 to current story, then you create one start from current story 1500 and the height is 1300.
Dwight
You'd be making a complex profile and extrude it as a wall. You then assign different materials to the different fills used to make the profile. See:
http://www.archicadwiki.com/Creative%20Uses%20of%20Complex%20Profiles
As for horizontal changes, you change the profile.....
Dwight Atkinson
Dwight
And for vertical and horizontal changes at the same time, you need to make the shape from out of the wall surface by making another complex profile...
Dwight Atkinson
Djordje
DDJUSA wrote:
Hi All,
Sincerely,
DDJUSA
Look up Complex profile, as Dwight suggested.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
