‎2006-02-13
01:28 AM
‎2023-05-11
01:00 PM
Noemi Balogh
‎2006-02-13 06:38 AM
KeesW wrote:it depends on the direction the walls were drawn . . . but the good news is that you don't have to re-do them. use the 'modify wall' commands in the edit menu to switch, flip and generally mess around with wall direction and reference line issues . . . ('invert direction')
Do I have to redo all my outside walls, using an offset rather than a centred control line? Or is there another way?
Another thing about texures and fills. One often wants the fill to appear on the outside and vertical faces of walls, but seldom in the horizontal cut face, or on the top.the cut face of a window? or the top 'edges' of the wall? you can change both: the later from the wall setting itself and window/door cut horizontal faces can be controlled in the window/door 'model' pane . . .
‎2006-02-14 05:24 AM
