Visualization
Washed out interior colours with v18 render
I'm having a problem with photo renders using the new rendering engine in v18. I am rendering an interior view but the colours being washed out - particularly on a red feature wall.
I've attached a screenshot that shows you the "basic" 3D window and general colour the wall should be, plus an inset partial render of the red wall - which in the photorender is pink!
I have also attached a screenshot of my settings for reference. AS you will see, I've used these settings before in the same project and saved them so I could replicate the render after making changes to the model...well that was my plan!
I've been using archicad for ages, but am a real amateur with the rendering side of things. Any suggestions for settings etc?
1 REPLY 1
David Maudlin
Metroworks:
The first thing you should do is go to the Surface Settings for this Surface, change the Engine Settings: to CineRender, then look at the Color setting. You could post a screen shot of that dialog box for feedback. In your attached pdf file I see only the 3D Window and the rendering. You can also try the Match Settings... CineRender to match from Internal on the CineRender settings page.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
