camera publishing
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-01-21
01:42 PM
2023-05-11
01:19 PM
Noemi Balogh
2008-01-21
01:42 PM
Can anyone explain to me why the manually rendered camera view does not match the same camera view generated with the publisher?
Many thanks,
Joaquim
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-21 01:50 PM
2008-01-21
01:50 PM
You probably have different settings for these two cameras...
To match them you have to open the right camera with the right settings...
Then go to the publisher and select the "published" camera and open its settings and...
check the box "match the current 3d settings" (...Or something) and save it...
Hope it helps.
Hope it helps.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-22 05:30 PM
2008-01-22
05:30 PM
jagostinho wrote:Your view is not saved with the same settings.
Many thanks,
Joaquim
Generate the 3D window with the camera, check the rendering settings, select your view, match the settings to the current window. That should do it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
