Visualization
camera publishing
Can anyone explain to me why the manually rendered camera view does not match the same camera view generated with the publisher?
Many thanks,
Joaquim
You probably have different settings for these two cameras...
To match them you have to open the right camera with the right settings...
Then go to the publisher and select the "published" camera and open its settings and...
check the box "match the current 3d settings" (...Or something) and save it...
Hope it helps.
Djordje
jagostinho wrote:
Many thanks,
Joaquim
Your view is not saved with the same settings.
Generate the 3D window with the camera, check the rendering settings, select your view, match the settings to the current window. That should do it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
