can you update camera positions?
i have a little problem i could with some help.
scenario: you have place a camera in plan and then used it to create a 3d view.
in 3d i start to move around to get a better view.
question: is there anyway that i can save the view as a camera or update the original camera in plan so that it reflects the new view. i know you can save views, but id like to be able to manipulate cameras in a path before making a flt through, and to take higher res pictures from the cameras in the path, so they can be edited into a movie late.
any help would be greatly appreciated.
id prefer not to use Artlantis, if that possible
thanks again!
3 Replies 3
Eduardo Rolon
Once you have the 3D view as you want, right click on the camera in the navigator window and choose "modify this camera to current view".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
works a treat!!! thanks heaps
Just to confuse you here is another way...
If you have the camera highlighted when you go to 3D there is a little arrow on the corner of the 3D window pallette, if you click this you get all sorts of nice options.
Julia
