‎2007-01-02
07:05 PM
‎2023-05-11
12:28 PM
Noemi Balogh
‎2007-01-11 03:56 PM
WhiteMan wrote:Your picture looks very good, i like it. The problem here is the rendering time. You needed 1hr to render two walls, window and glass table with torches. Now imagine some complex house in high resolution. It would take at least one day. And what if you want to change something on the pic that was rendered for 20 or 40 hours before and u need to render it again?
I also started to work on my rendering about 7 months(before I used Lightworks 😄 ), and I have to say that v-ray is the best for me. After you build the model in ArchiCAD, save it like .3ds, import it into 3d max, and render it with v-ray.
On the other hand it si not easy to learn 3d max, v-ray
here is my result after half of year learning 😄
‎2007-01-11 06:12 PM
