Visualization
dichroic glass material
Pato99
Hey Guys,
I'm a bit stumped on producing a dichoric glass material. I'v tried a few things but it's just not working.
I'm hoping someone could give some direction on how this could be done. I know Lumion so I would suggest it's achievable.
Here is an example: http://picssr.com/tags/chameleonlab/page3
This might give some hints:
Thanks for any help!
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
Erwin Edel
Just an idea: fresnel shader, you can set two colours for the gradient, should change colour depending on your viewing angles? Just put it on the 'color' channel.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
Did a quick test with transparant and just reflective material, not as striking as your examples, but I think you might get some results out of this.
www.leloup.nl
Windows 10 Pro
