lights in Art*lantis 4.0
how could i select more than one lights and change the settings just one time for all?
12 Replies 12
Djordje
You can't.
BUT - you can, by editing the DB file in the text editor. There was a tip by a French user on the old Talk, it probably can be found on the eScribe.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
if you press CTRL in artlantis (in the creating new light window )the next light created will have the same settings with the previous
P.S. if you want to activate the special menu in artlantis you must do this :
in edit shaders menu window keep press SHIFT and in the same time type the next text
((EXPERT)
and you will see a most complex shader editing menu
to activate another special hidden shader menu you can
tipe a second command
((MNSHADER)
Djordje wrote:
You can't.
It might even be found from a non-French user ...but perhaps I repeated his/her tip. Of course, with 4.5, Artlantis no longer uses the OPT/DB combination - both of which can be edited in a text editor - but the single ATL file (which is still editable).
Editing is one way to revise lots of things at once; I've only had to do it on one project quite some time ago.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
the dificulty to set lights in artlantis is one of the major weakness of this program for an interior presentation i put a lot
of lights manual to give accents on volumes and i missing the hidden continous neon light between to ceilings levels to create
indirect ilumination
((EXPERT)
((MNSHADER)
I'm obviously missing something somewhere: could you explain it again for a moron?
Thomas Holm
A small tip: To edit the huge Artlantis .db or .atl files, you need a text editor that can swallow huge files and perform fast searches without changing anything that's not to be changed, On the Mac I recommend BBedit. The freeware Lite version will do.
Thomas
Only for the Italian-speaking ones. 😉
http://www.archiradar.com/eng/relatedsw/Artlantis/Artlantis-menunascosto.htm
Ciao
PS For the rest of us, http://babelfish.altavista.com sort of translates (paste in the url from above) ... but the Italian is almost easier! The English translation is pretty amusing anyway.
Djordje
... and the URL is ... ?
Djordje
HP Omen
Djordje wrote:
You can't.
How can i do it?
