2003-11-12
12:30 PM
2023-05-11
02:40 PM
Noemi Balogh
2003-11-12 04:32 PM
otylyka wrote:You can't.
how could i select more than one lights and change the settings just one time for all?
2003-11-12 05:42 PM
2003-11-12 06:06 PM
Djordje wrote:It might even be found from a non-French user ...but perhaps I repeated his/her tip.otylyka wrote:You can't.
BUT - you can, by editing the DB file in the text editor. There was a tip by a French user on the old Talk, it probably can be found on the eScribe.
2003-11-12 06:30 PM
2003-11-12 11:17 PM
archibaldo wrote:
P.S. if you want to activate the special menu in artlantis you must do this :
in edit shaders menu window keep press SHIFT and in the same time type the next text
((EXPERT)
and you will see a most complex shader editing menu
to activate another special hidden shader menu you can
tipe a second command
((MNSHADER)
2003-11-12 11:20 PM
2003-11-13 08:28 AM
Shaun wrote:Only for the Italian-speaking ones.
I'm obviously missing something somewhere: could you explain it again for a moron?
2003-11-13 01:03 PM
Karl wrote:... and the URL is ... ?
2003-11-13 01:10 PM
Djordje wrote:otylyka wrote:You can't.
